I wanna make this a rider. I have already started cleaning it up some. It has silver paint on the engine and wheels. I already have the rear rim cleaned up. I do not know why it was painted because it is nice and shiny chrome under the paint. No rust on that one. The front is a bit harder to clean due to the paint being heavier and there is some rust scale on it. I am not sure how nice I can make the engine. Right now i do not plan on taking the engine out or disassembling it. I will clean what I can. It does run. I have tuned it and changed the oil already and took it for a short putt up and down the driveway. I do need to get a front tire due to weather checking. I have mirrors on the way and a new shift lever (the one on it is mangled!). I also have a center stand coming from a 75 CB360. I figure it should fit. I just need to figure out where to hook the spring on the frame. The exhaust I have coming is a MAC 2 into 1 system. It says it will retain the centerstand and oil filter access. The muffler was full of holes. I am still looking for a seat lock. That is missing. There was a small tear on the seat so I stuck a small patch on it.
I also may need the rubber bushings for the handlebar mount bolts. The handlebars wobble back and forth. I need to tighten them up somehow.
