Hello All,
I am putting the finishing touches on my CB360 build, and I started it again for the first time last night. I kicked it over a few times and it fired right up, however, the engine raced up to a high RPM immediately and I had to kill the engine before it over-revved. The motor is stock and ran fine prior to teardown. I swapped the stock airbox for a pair of velocity stacks, and the exhaust is a aftermarket 2-into-1 MAC setup, which was on the bike already before I started the build.
The throttle is functioning properly- closing completely and opening completely without binding in the cables. I turned out the idle mixture knob to it's outmost setting and tried again, but still the same thing. The bike is running the factory jets, which seemed to be fine with the MAC prior to teardown. I assumed I would have to up-jet it for the stacks, but I wanted to leave the jets stock for the first start to get a baseline, and then tune as needed. I thoroughly cleaned and closely inspected the carbs during the build, and reassembled without changing any of the mixture screws from what they were before I tore the bike apart.
Does anybody have any ideas why the bike would race up so high immediately after starting? Floats are set to spec, and there are not any leaks from what I can tell in the rubber boots between the head and the carbs. Would I have to change the mixture screw settings for the pods? Any suggestions are greatly appreciated!
