I am bringing this over from .com. I am also a member there.
Well here is my twin project. I got 4 bikes a couple of weekends ago. This 7300 mile 75 360T was one of them. someone had taken this bike apart for some reason. I found out what was the reason for the motor removed from the frame. The valve cover was off it...and I turn it upside down and notice one of the rockers is missing. why would someone remover the rocker? I had traded the other night for another 75 360. It was junk...no title and alot of parts missing. so I pop the valve cover of it and put it on the other motor. Make almost a whole revolution and stops. This isnt good. So I take the valve cover back off and turn the motor over and over...no problem. so I pull the head off...and sure enough...valve bent. Ok. Not a problem. changed the head. Compression check says I am good at 120 in both sides.
I am just putting this bike back together to see whats going on with it and see whats missing. I got alot of the parts that was missing when I picked up the other 360.
Things missing so far:
1. Tail Light lens. Of course the one I had on the shelf I knocked off the shelf and it shattered.
2. The little piece on the swingarm that the adjuster bolt butts up against...onlt one.
3. Both side covers. They were in the bottom of a crate busted up bad.
4. Petcock
5. The exhaust pipe. Who knows what happened to them. This is a CB 360T
6. Not missing...but junk...the seat.
7. Clutch cable. MIA..no idea.
8. This is a given...battery.
I will probably get up early in the morning and work on her some more. I know I will find more missing.
I will get some pics soon.
4. Petcock
