So here is the biggest issue with my bike that is preventing me from trusting the bike past my immediate neighborhood.
NOTE: I am running a brand new MotoBatt AGM battery that is always fully charged, and on a tender when sitting for a while.
I put the key into the ignition switch, and set the bike to "ON" and the Neutral light comes on.
I flip the handlebar starter switch to "RUN" and the neutral light shuts off. No starter, no lights, no horn, etc. I checked my fuses for a short, and all of my fuses look perfect. If I cycle the key switch from off to on again, the Neutral light faintly comes on. It is almost as if the bike is acting like it barely has a charge.
Here is the interesting bit...
If I kick the bike over while it is "dead", the lights come on and it immediately starts to run. I found that if it is left idling, then as soon as I use a turn signal (for example), the engine cuts out. However, if I am revving the engine anything past idle, the bike can handle the electrical loads.
I hooked up a voltmeter to my battery to see if I am experiencing a sharp downturn in charge while using any of the switches, and to make sure that my charging system is actually charging the bike at 3-4k rpms. Nothing abnormal has been observed.
I took apart the headlight and opened up the "bird's nest" of wiring up there and verified that I have no loose wires.
I made a video documenting my findings from today which can help illustrate my issue.
