Hello everyone, I just discovered this site and was hoping for some advice.
I rescued a 75' CB200 from a barn for all of $20! Has only 6,000 miles and according to the DMV I am the first official owner. Over the winter I rebuilt/cleaned the carbs and located some of the missing lights, parts that were missing.
This spring I fired it up for the first time. It seamed to run fine as long as the RPMs' were HIGH. I took it for a ride down the road and noticed that it had NO power when I tried to climb a hill. I added some throttle and at 4,000 RPMs' it took off like it actually had power. When I got back to my driveway it still wouldn't idle and I felt the exhaust manifolds. The right was HOT and the left was cold. When I started it I noticed that the right was the only side actually running, the left was cold to the touch again...EXCEPT when RPMs' were over 4,000 then both cylinders actually run. I have good compression, there is strong spark. The left carb float bowl didn't look like it had as much fuel as the right so I rebent the tab to the correct measurement and it still didn't seam to have a difference in how much fuel was in the bowl. No matter how I bend the tab it doesn't change. When the float is down fuel does run out into the bowl though. Any suggestions on what to do now to get the cylinder to light? (picture is the day I bought it, just rinced off the dust with a hose)
