and after that, you should properly introduce yourself in the Members Introduction area so we know a little about you and your bike
Yes I will. I did note my first ride was a BSA Victor in the late 1960s. I also had several late 60s early 70s Truimph 650s, bonnevilles, and tiger. The tiger I loved. So easy to work on, Had the unit transmission, so it was easy to get apart. Also bought a new triumph back in 1977 I think. It was a 750 5 speed. Had shift on your left foot then. Got a yamaha enouro off the floor new back in 73 or 4, dont remember. Cost about $680.00 back then. Moved to another state, and let my license go. Im in Kentucky now and was itching to do something so bought a CB360. Mainly because its a small bike, about the size of my triumph tiger of years ago. Easy to drive for me.
I opened it up, set the cam, installed new seals, put in new points, Timed it, and set carbs but the engine started to runaway with me on it. I had to hit the kill switch to save myself. This had to stop. I read all the articles about wild idle speeds coming on so set out to solve the problem. I immediatly knew it was a carb problem, so took off the carbs, and minutely checked them. The bellows in the slides were supple but torn in the folds, and were causing the problem. I took out the jets, replaced just the idle ones. Did NOT replace any of the others. I never risk changing altering a factory matched item like that. Checked floats,were fine, checked needles fine, just put them back in. Looked at the throttle plates for syncronization. Looked just fine. Just left it alone. Buttoned it up, and turned on the gas. Set the idles a couple turns out, hit the switch and it runs like a top. Idles dead smooth, and draws power evenly no flat spots. I also put in a 17 tooth sprocket, so it really pulls nice at higher speeds, yet does great on the street too.
I remember the saying from the 1918 Curtiss Aircraft manual "Avoid the dangerous habit called tinkeritus. When the motor is running smoothly... LEAVE IT ALONE.
Im going on 72 years old and look to enjoy my little Honda 360 the rest of my life. I drove it 200 miles this past sunday, and loved every minute of it. I hope I can contribute a few common sense things to this forum.
Carol Ann
