1 - 1 of 1 Posts
Does anyone know the how much current is supposed to be going into the ignition coil on a 1974 Honda Cl 200 Scrambler under normal running conditions? Also, does anyone know the ohms spec on a stock Honda CL 200 ignition coil (i.e. "I got a 3 Ohm coil")?
- found the ohms, it was an easy test whit a multimeter on a working coil between the positive and negative leads
1 - 1 of 1 Posts
