Just picked up a 73 cl 350 twin . gas leaking from hoses under bike !? only running on one cylinder ? have spark on both . HELP
Clean carbs and adjust floats....You're flooding..... Then change the oil.........
Will do , one more ? the tube thats is in the bowl is there only a hole at the top or should there be holes on the sides .
Thanks
sounds like sticky floats. tap the bowls with a rubber mallet when you turn the fuel on. may help.
and like Steve said. clean carbs, change oil, check float height.
if you just picked up this bike, make sure it has clean fuel or the carbs with clog up again. Fresh high octane and a good petcock screen (or small inline filters) will keep you from re-cleaning your carbs a million times.
Hello All,
Im need to find rebuild kits for the carbs on a 1972 sl350
engine # sl350 4141355
can anyone help ?
