Good little vidio pio, any pictures of the mechanical carnage ?
Good point Ben...
Wade, did you look thru the plug holes ? Do any of the valves look odd and any damage seen seen on the piston crowns ?
As you know the engine has to come out to remove the cylinder head, however, from memory, the cylinder head "cover" is removable with the engine in situ giving a good view of the camshaft, rockers and valves, but if you do that, place washers over the studs to make up the lost "thickness". Remember that the "rocker arms" alloy carrier casting held on by peripheral 6mm bolts ( 10mm hex heads ) is being "forced up" by the valve springs when valves are open....
There may be some benefit in removing the lid, but I don't have your engine in front of me.....
Pictures pictures pictures with the engine "as is"....
Do your checking with the engine "as is' for now.
With plugs out and turning the engine over by hand, or gently with a ring spanner, any tight spots felt ?
I presume you have cleaned the cb points only and have not introduced an incorrect ign timing ?
As said, it could be crud stopping that inlet valve from closing completely.....how are the valve working clearances ???
A bright torch shone thru that inlet port ( carbs off ) when that valve should be closed, any light seen thru plug hole ? Valve working clearance large at that point.
Feedback as it helps others.....
Hope no carnage.....
Dd23🤓
