Parts look clean, so it looks to me like only one careful, methodical day of assembly away from running. Why did you pull the studs out of the cases?
The only way to get the cases inside my small vapor blaster to clean them was to remove the studs. Actually....I could get them in the blaster but could not move them about enough to easily clean them.Parts look clean, so it looks to me like only one careful, methodical day of assembly away from running. Why did you pull the studs out of the cases?
Can you show that small vapor blaster......I'm probably gonna get one myself.The only way to get the cases inside my small vapor blaster to clean them was to remove the studs. Actually....I could get them in the blaster but could not move them about enough to easily clean them.
Thanks for the information. Now my wife will not kill me for messing up the kitchen.Baking regular paint speeds-up the curing, but doesn't increase the durability.
Some high heat paints require it and are very specific about how to do it.
Duplicolor doesn't usually require it. VHT high heat does.
You betcha!Thanks for the information. Now my wife will not kill me for messing up the kitchen.
