It’s the castle style socket for the oil filter.What special spanner are you referencing for the bottom end?
Frame looks great. What did you use?Frame and swing arm ground and ready for primer and paint. Got my top end bead blasted while I try to remove the gaskets. Also ready to split the case! Fun, fun, fun!
I used an angle grinder and steel wire brush.Frame looks great. What did you use?
