I’m rebuilding my cb350 and came across this plate that sits underneath the crank shaft in the bottom case. It has two screws and what appears to be three pins of some sort hold it in place. I removed the screws but I’m not sure about the best procedure for removing the pins. I want to remove the plate so I can clean out any debris underneath it. Hopefully someone has dealt with this before. Thanks.
