Hello Friends,
Today I got my new to me CL running, but only on 1 cylinder. Right side exhaust pipe is cold and engine revs do not respond when lifting the right side carb throttle manually. A spark plug grounded to the engine shows no spark on the right side. I've tried adjusting those points a bit each way with no better result.
I did notice a weak spark on the right side with the ignition on and manually separating the points.
What would you suggest I do next? Obviously I'm just a mediocre mechanic.
