1971 CL175
Im getting ready to remove the engine to complete a top overhaul. All the engine mounts are out except the rear bottom bolt. The engine is being held up with a scissor jack. All the electrical wires, grounds are off. Whats the best way to remove the engine itself? Left side? Right side? Twist here? Lean over there? There is always some trick to get these things out. Thanks in advanced.
chuck
chuck
