If I hadn’t just done the same thing, I’d pick them up. Great work - will make someone very happy ��
Edgar..,not sure about 74, but my 72 and 73 have identical carbs..
I did discover that (not sure years) these carbs "changed" when I was shopping for rebuild kits.. if displacement is the same, intake dia. (mm) also match.. I think your good.. unless physical fitment (frame/tank) gets in the way..
I've seen classic English Amal carbs on a 750, my Triu**h 650 had converted 2 stroke PKW/JRC carbs..
I did discover that (not sure years) these carbs "changed" when I was shopping for rebuild kits.. ..
Some of the changes were at K1 (to 14H), then at K5 again (to 722x series).
