It was a beautiful spring evening in Wisconsin, so I took my CB350 out for a ride through America's dairyland. Once I got out onto county roads, I noticed some weird activity at higher speeds/RPMs. In 4th and 5th gear, I could not get above 5,000 RPMS, nor could I get much above 42 mph. If I continued to throttle up, the engine sounded bogged down - like it wasn't getting enough air. I would also start to lose speed/RPMs. I haven't tested exactly, but I'd say it happened at the final 1/3 of throttle travel.
By way of background: I've owned this CB350 for about a year. Last year, I definitely did not have this issue. After a long winter, I drained and refilled the tank, changed the oil, checked tensions, etc. but otherwise the bike is stock. The only other issue it has is electrical (which I'll post in the proper forum).
Any ideas?
Any ideas?
