Hi, folks.
Okay, update for today (so far) contains both good and bad news. The good news is that both cylinders are now working! I won't say they're balanced yet, but at least they're both making a healthy contribution. For the first time, the left side is getting hot, the bike is revving more quickly, and it will now settle down idle RPM. So, obviously all my efforts to eliminate air leaks were finally successful! Now, of course, I need to get things in balance, and set the mixture, but I'll definitely call this part a win.
The bad news? My previously fluid-tight motorcycle is now apparently half swiss cheese, and half sieve, as it is leaking both oil and fuel (the latter prodigiously). I'm not worried about the oil, as that is just coming out of the cover over the stator and rotor, and I'm assuming that I just failed to tighten it sufficiently. Worst case, if the gasket there is damaged, I should have a spare in the engine gasket kit I purchased recently. The fuel is a different story, as it is literally pouring out all around the float bowl gasket on the right side, and at least some is leaking on the left side. The float bowl gasket is one of the few that I chose to still use from each of the crappy carb kits that I purchased, and the reason I did is that the originals were hard and looking like they were ready to start cracking. I'll check again to make sure that the gaskets are in their proper places, but I'll plan to change them out soon, regardless.
Two questions for the group:
1. Can anyone recommend a source for good quality carb kits?
2. Does the fact that the bowl gaskets are leaking indicate that the float level is too high, or that the needle an seat are leaking? Or, is there always the potential to leak there if the gaskets are bad?
Thanks again for all the help!
Shaun
Shaun
