Hi folks,
Recently swapped out my 70 engine for a 71 on my SL350. Progress is good except for the clutch adjustment. Basically set the cable close to slack, and the adjuster so that the cam is about mid way. All seems fine for awhile and then with clutch lever pulled in something "pops/derails" so that the cable goes slack and doesn't work. I pulled it apart a couple of times trying to find something obvious but it looks ok?
I have been doing videos of the project and the video below #6 will show how I have the adjuster. The only thing I'm wondering is if the one ball bearing in the "spaceship" trio is popping out and then back in
Clutch work starts around 5:15 of the video
