1970 CL450 Speedo cable. I have the front drum brake set-up. Pm me if you have one for sale, even if you have just the inner, that would work.
I checked with Motion Pro, they only show throttle & clutch, no speedo. Do you happen to have a part number?
Tim, the 1974 won't work, but thanks.
02-0047
For the CLs, motion pro lists a choke cable (which the bike doesn't have) and a clutch cable (which doesn't work). You have to use the speedo for the CB450. The CBs and CLs used the same one. It works fine on mine, but it's a '72.....K5.
Does your cable have threads on the end at the wheel?
Or does it slide into the speedo ftg at the wheel and get retained with a screw like the one below?
If it attaches to the wheel like the picture, then the motion pro one for the CB450 will work.
Yea, my cable threads onto both ends, not like the one in the picture. I actually have quite a few of those.
Thats the one! Thanks.
