Just to confirm...once the engine is started and warm, the choke lever/arm should be moved to the vertical position for riding, correct? See pic. Thanks!
310935
That's correct. If you look closely at the choke lever there's the word "OPEN" with an arrow pointing the direction to move lever to accomplish that. BTW, Open is where it needs to be for normal running after warm up.
