Hello everyone,
I own a 1970 cb350 twin and the previous owner fit it with a 2-1 exhaust that unfortunately covers the oil drain plug. When I was disassembling the exhaust manifold/collar assembly to access the drain plug, I must have not been paying close enough attention (I know, rookie mistake) and now as I'm reassembling it, I'm noticing that the pipe joint collars (#2 on diagram below) are different sizes. I have four collars in total - two for each pipe - and two of them are shorter than the other two, so I have a pair of longer collars and a pair of shorter collars. The difference is about 1/8th of an inch.
The collars within each pair are the exact same size, so it seems like something that would come stock...?? If so, which cylinder do the shorter ones go on and which do the longer ones go on, or are they each supposed to have a long one and a short one?
I can upload pictures of my actual collars tomorrow once I disassemble the exhaust again.
Any input helps!
Any input helps!
