1 - 2 of 2 Posts
The header pipe for my 1970 cb350 broke off (left one) and my right one has a pretty large crack in it.
Has anyone had any experience welding a piece of equal width and circumference to copy the ring? If that doesn't work, I'll have to replace it. Which leads me to my next question- Can I replace the 1970 version with a later version? The later versions have a much thicker flange.
Thanks
c
yes and yes. the later versions were stronger all that's needed to swap them is to also swap out the collars on the mounting flange or cut down the 4 you have to fit.
1 - 2 of 2 Posts
