Hi gents,
Just finishing off the rebuild on my bike and im having an issue with the brake lights/position lights. Electrical is stock - original harness - everything has been checked and tested. The headlight in the bike does not have a position light. The original wiring diagram contains one. I have a parts bike and checked the wiring on that and its the same. Here is the issue im having.....
1. The rear brake switch works when the green/yellow wire isnt hooked up to the front brake switch. The position light on the tail light does not work.
2. If i hookup the front brake switch, neither of the brake switches work but the position light in the rear tail light does.
I know i missing something simple here with the brown wire but i just cant figure it out. Any help is appreciated!
Check all your grounds - tail and brake lights often work very weird when the wiring is trying to find a ground through another avenue, whether a switch or bulb
That was my first thought also. The grounds all seem ok. Should mention everything else electrical on the bike is working.
