working on restoration of this 69 CD 175 and rebuilding the single carb on this model. on removal the insulator cracked and after searching for a replacement part #16213237010 it seems they are not available any longer so wondering if repairing the old one is an option or does anyone have a replacement suggestion for me.
You can order TWO of part number 16211-943-306 and make (use) an extra gasket between the layers (they are only ~2mm thick each).
Note that for optimised flow, a slight enlargement of the center (air/fuel flow)hole is indicated......Please phone for specifics....540-525-5199
Steve
Thanks Steve
Are you saying double up the 2 with a gasket in between ? the original is pretty thick but when I get back to my shop I will measure it. I was thinking of maybe gluing it and then some type of rubber coating to finish is that a bad idea? or will the 2 double spacers get me the thickness I need?
