1 - 1 of 1 Posts
Hello All
I'm new here and have been digging around trying to find anyone that has come accross the rollers going away and if they are rebuild able?
I'm working on a 69 450, it was brought to me to try and diagnose why it ran so bad after it had aparently been worked on by a self proclaimed expert, what i found was he had left the washer out of the shift lever sprocket guide allowing it to jump away from return spring, replaced timing chain but added 2+ links so the adjuster couldn't compensate allowing chain to slap the inside of the case on the exhaust side and the exhaust side roller is wasted.
So I have a donor motor but the chain roller shows significant wear as well, does anyone know if they can be replaced or is it a assembly that should be replaced.
Any help is appreciated.
Greg
1 - 1 of 1 Posts
