JT
Thanks but I don’t see “SL3A” on the list or any other list in any book or manual. I assume I am misssing something obvious? I can’t set the floats to 19mm so that eliminates the “350A” and the Venturi is 28mm so that eliminates the “A”. The jets in the carb are #105,#70 and #35. These align with the “3-D” but I don’t know what the POs did to the carbs over the years. Engine # SL350E-10048xx.
Thanks for the reply!
Dan
I received this information from Randy at Marblesmotors, Thanks Randy!
SL3A
Float Level
26.0 mm
Standard Main Jet
#70 Primary Jet
#105 Secondary Jet
Standard Slow Jet
#35
Idle Mixture Screw Initial Settin
3/4 turns from closed position
Idle Speed
1200 rpm
Randy Marble, Managing Member
Marblesmotors, LLC
Homepage - Marbles Motors
214.686.0044
