I'm restoring a 1968 CL350. I am trying to lower the front end forks without replacing the whole front end. The top triple tree is the kind that doesn't have the clamp, but i was trying find one that will fit with a clamp but had no luck (unless replace all of it)....
So, i had this idea where i could buy another bottom tree, remove it from the steering stem (using a machine press) and replace the top tree with it. So basically i would have two bottom trees for the top and bottom so both trees have clamps. I could then feed the forks through and raise and lower the height accordingly. I would also have a clip on handlebars which act as support so the trees don't slide down when riding......
Would this work?
Would this work?
