1 - 1 of 1 Posts
Really need some help. How do I test the stator, the wires seem to be Yellow, White, and Brown, when disconnected and the bike slightly above idle, checking to ground I get 10vac on brown, 13vac on white, and 15vac on yellow. If I increase the rpm the voltages rise equally. I am assuming the brown is the pink because that is what is on the other plug going to the battery. When not running,there seems to be a short brown (pink) to White but not to ground. oh, when running and hooked to the Rectifier..no DC out.
If I swap the white and yellow going to the rectifier I get 25 vdc out of the rectifier with 25vac going in.
1 - 1 of 1 Posts
