1965 Honda CB 160
looking for a starter that works.
mine will turn manually, but won’t engage when I hook it straight to a battery with jumper cables
1965 Honda CB 160
You might pull it apart and look at the brushes, could be all it needs. Lots cheaper than a used starter that may be almost worn out too.
1965 Honda CB 160
Moved to Parts Wanted
Do you mean that the starter motor runs but won't engage the engine to turn it over? Or that the starter motor itself doesn't actually run with jumper cables?
Discussion Starter #5
inhave never done that before, but I am really mechanical, where would I get replacement brushes and how do I know if they are bad?
