1 - 17 of 17 Posts
Hey there guys- my first post although if overcome some issues reviewing earlier posts.
Rebuilding a ‘71 350 K3. Learning by making mistakes. Today while installing fork seals (which I achieved) I thought disassembly was achieved by removing the small Phillips head screw at the underside of the fork where it sits on the axel.
I had to use an impact driver to lose that screw - seems that was a stupid idea- the screw broke free but now turns freely without coming out.
I don’t know what I’ve damaged but I can tell that this fail will cause a leak - what is the solution… is there further disassembly still required or should I have that place where the screw is welded over; I’m at a loss - can anyone help?
Household hardware Bicycle part Tool Gas Wood
I know it doesn’t show on the parts fisch … I’m baffled - I don’t know what else is down in there - the screw spins freely (loose) but doesn’t thread out.
Initially I thought I broke the head free of the shank but no, the head is still connected to something.
I do see a tube inside the bottom tube but I’m afraid to go any further at this point.
suggestions ?
This is the fork type.
Hypodermic needle Bunsen burner Wood Medical equipment Paint brush
Screw doesn't need to come out to take apart the early forks. Remove the fork tube and you will need to fashion a tool to hold the piece that the screw goes into while you remove the screw. Clean the screw and tube up. There should be a copper compression washer so don't lose it. You can use a small amount of sealant on the screw. Using the tool you have made hold the interior piece while tightening the screw .... I would use a battery powered impact.
If you have a battery powered impact you may get lucky by short power pulses on the screw while it is assembled by it would be a shot in the dark. Not going to work by hand.
Boomer.
I’m not pickin up what ur layin down…. help a bit more please-
there is a tube inside the bottom tube / are you saying the “tool” I must fashion will be inserted into that inner tube to “hold” something?
I can try that but I don’t know what or how to fashion …. Anything else helps save me… is there a description of the unseen interior you can provide???
mine does not have the Allen bolt - it has a Phillip’s screw.
I found this but still don’t clearly understand how to resolve my issue. I’d prefer to simply tighten and move forward but I don’t know how to accomplish
Rectangle Font Parallel Slope Screenshot
· Administrator
you should be able to remove all but the inner dampening tube then use a wood dowel to hold it while you either remove all the way or tighten it back up
Ok .. I’m feeling optimistic now - I just want to tighten as I’ve done the fork seals and that’s enough.
what I take from the reply’s is insert a dowel (or broom handle sized wooden tool) which will hold the inner tube steady while I tighten the screw.
Correct?
I’ll try this tomorrow and get back on the thread to advise if it worked. Totally appreciate the assistance - awesome ! JD
. . . I just want to tighten as I’ve done the fork seals and that’s enough.
Dunny,
Of course, do as you wish, but I would say that since you already broke the screw(s) loose and found yourself a wooden dowel tool, I would take the screws out and remove the tubes. I say that for a several reasons:
  1. Once the screws break loose, you should have no trouble removing them the rest of the way with just a plain screwdriver while you hold the wood dowel against the tube to stop it from turning. Here is what that little machine screw looks like:
  2. On my '70 SL350K0 forks that I recently rebuilt, there was so much muck and corruption in the lower sliders and in those cushion tubes that it took a long time to clean them even when they were fully disassembled. Yours may not be so bad, but mine was a basket case / long-term barn bike. I was using a recirculating parts washer with mineral spirits and a variety of brushes. It still took a long time to get them cleaned out. I never would have gotten them clean without taking them apart.
  3. If you remove the screws, you can anneal and reuse the copper seal washers. Take the washers out with a seal pick. Bend a little hook on the end of a piece of wire and put the washers on there. Hold the copper washers in the flame of a stove burner or a propane torch till they flash cherry red. Douse them in cold water. They will be soft and pliable and will seal as well or better than a new washer. That prevents getting the forks all back together and having the lower screws weep oil.
Stay optimistic!
Discussion Starter · #16 ·
Ray- thanks for the photo (that’s helpful) and excellent advice -
Im going to get at this later and will come back to explain results. This has all (everyone has) been very helpful - much appreciated. (I’m doing an epoxy lining on the tank today). JD
Discussion Starter · #17 ·
Hey - thanks everyone for the feed back - it’s been phenomenal - I was worried I had screwed this one up but the feedback here saved tons of worry. I did as advised and - total success- did it ever feel great.
a couple of photos to prove it .. and to make the photos clear in the event I can assist another rookie..instead of a broom handle I used a pliers in the inner tube. The pliers have a soft grip handle which allowed a slight angular and tight fit with a “handle”
That was offset to resist the torque of tightening.
Hand tool Tool Metalworking hand tool Musical instrument accessory Wood
So I’m getting close to complete (l wager I’ll h
need more help with that soon too!)
Wheel Tire Fuel tank Automotive fuel system Vehicle
Thanks again. JD
1 - 17 of 17 Posts
