Tank looks good, so does seat. Don't ruin seat with dookie brown leather. Black leather!
Ha! Maybe you're right. I might take the old seat cover apart and use it as a trial run. Can't hurt to see how it would look in black, and it's free!Tank looks good, so does seat. Don't ruin seat with dookie brown leather. Black leather!
Does anyone have any thoughts regarding drilling out these mount holes?So I tracked down the long threaded rod that goes through the bottom mount on the frame and engine that I was missing. Now I have the issue that the hole in the frame is 10mm diameter and the bolt is 12mm! Did they go to a larger size in later models? I had a hard enough time finding this rod at a reasonable price that finding another, and potentially having the same issue, does not sound great. Would it be out of the question to carefully widen the holes in the frame to allow the larger rod? I'm not sure if the engine hole is 10mm or 12mm, I need to pull the engine out of the frame to see. Best I can tell this is not a structural point, but just another mount for the engine, but I'm also not an expert or an engineer!
