I took the head off and this is what I found....
I think these are the 3 parts you are referring to......
The right side appears to still be fine
But the left definitely looks like it needs to be replaced. I assume I have to replace the whole piece?
And the camshaft looks pretty bad
So it looks like I'm on the hunt for parts. While I have everything apart is there anything else I should be doing in the head? clean the valves with seafoam?
