HondaTwins.net
General Discussion
Smaller Twins: 125-200 cc's (CA,CB,CL,SS) '59-'76
250's and 305's (CA,CB,CL) - 1959-1968
250's, 350's and 360's (CB,CL,CJ,SL) - 1968-1976
DOHC 450's and 500's (CB,CL) - 1965-1976
SOHC Twins 125/250/400/450(CB/CM/N/Rebels) '78-'08
Classifieds
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Forum Support
Off Topic Lounge
Latest Posts
I have a 73 cb175 that has a charging issue. At 5k rpm the battery will only keep charged at around 12.4 volts. It has a new regulator rectifier kit from common motor and a new agm battery.It will progressively get weaker and only last maybe 100 miles. The bike will die very quickly at night...3 replies 124 views
I have a 1974 CB450. It ran when I bought it. I have rebuilt the carbs (I took them apart a second time to make sure I didn't do something wrong) and added new throttle cable, petcock, and fuel lines. Now the engine starts when I spray starter fluid in the carbs but it wont stay running. I'm...2 replies 56 views
I just bought a 79 CM185, that's on a pretty good shape. The main problem is the previous owner put a 12 volt battery on it. He said he rode it for a few minutes and it died. I put a 6 volt battery on, and the starter cranks, the high beam comes on and the high beam light on the instrument panel...7 replies 109 views
I recently bought a 1982 Honda CM 450 E. While it was running, it was not running well at all. Spent quite a bit of time on the carburetor finally figured out the main primary and secondary jets were switched and now it runs great. I do have a question if anybody has suggestions for tires, I am...1 reply 42 views
