Site Logo
It is currently Sun Sep 05, 2010 6:51 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Re: HELP! Cl175 Sloper
PostPosted: Sun Apr 25, 2010 10:19 pm
Offline
90cc
Replaced the points and had it running with the new camshaft and bearing, but ran into the same lubrication problem. Pulled the engine back out and took the head off to find that I'm getting oil everywhere except the spot where the cam goes into the left bearing. Any ideas why that particular area would remain dry?
I think my cam and bearing are in good enough shape to reassemble, but I need to know how to get oil to it to prevent the same problem.
Thanks,
Scott
 Profile E-mail
PostPosted: Mon Apr 26, 2010 12:33 am
Offline
MODERATOR
User avatar
Here is the oil flow diagram from the Honda sloper manual:
I'll double check against my physical sloper engine parts tomorrow.....and verbally discribe the exact points to check for flow......
_________________
...It is WAY more fun to be at WOT on a small engined bike (as opposed to riding a monster engined bike only slightly above idle) .... "66" ...
 Profile E-mail
PostPosted: Mon Apr 26, 2010 6:08 pm
Offline
MODERATOR
User avatar
Verified!....The oil travels up the left rear stud passage and through a small hole and channel in the journal (aluminum cam bearing block) to the bearing surface...IF the gasket hole isn't aligned or the stud passages clear, you won't get oil..... There IS a small orifice on the cases where the base gasket goes....Wouldn't take much to clog it there....
_________________
 Profile E-mail
PostPosted: Tue Apr 27, 2010 9:38 pm
Offline
MODERATOR
User avatar
Any progress finding the blockage?.....
_________________
 Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: outobie and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Template made by DEVPPL Flash Games
